Craig:
I will bet that this is ignition-related. When the engine is cold, it requires a bit more charge to jump the electrodes. Try an in-flight, LOP mag check, and I'll bet the problem will identify itself. It likely will either be a weak plug or two or a weak harness.
Good luck.
Walter Atkinson
Advanced Pilot Seminars
