if it not vapor locking, then most likely the system is sucking air at the low settings.
start looking for fuel stains as when it is not sucking the higher setting will make it leak fuel. fuel controller, fuel strainers use "o" rings to seal the shafts i have more problems with old hard "o"ring than anything else. they get hard and crusty with 30/40 years
