Unread 07-07-02, 04:44 PM
GMAs GMAs is offline
George M. Amthor, Jr.
Wink Ahhhh draining the oil from the front engine... Hmmmmm
Yep I will have to send you the drawing on how to make a oil drain for the front engine... its real simple... we used to use the bucket trick like skyking says... but, then we got to where we wanted to catch all the oil and stuff we wash the engines down with... also... to be enviromentally correct... we came up with a pan tray thing that has a tank on the bottom to catch all the stuff... It slips right around the strut and gives you plent of room to get to the pan nut... all the oil drains into a bucket on the side... and we clean it up when we wash down the engine also... works great...
Ya cessna and cont engine could have done like the beach does.. and put the oil drain off to one side... so that you could get a hose on it like the rear one can... but, nope they had to do it their way... smile... GMAS
