Unread 09-25-05, 06:35 PM
Ernie:
Thank you for your post.
If the position of the forum has changed concerning personal atacks, let me say that it is for the best. Maybe a few slip through as in the one two mesages above. Maybe it should be obvious that members worthy of discussion use their own names. For that I thank you personally for doing so.
Now, on to a scientific and worthy discussion. You mentioned that you have some reservations about using some mixture choices. Since you are a man of science as an engineer, I would be most interested in your views and opinions which are able to be backed by any science or research of which I may be unaware. Let's look at this from a scientific point of view. I have a lot of data to share, if you are interested.
Just what concerns you about having more air than stoichiometric in a mixture charge? Let's take them one at a time and discuss the science as it is currently appreciated.
Walter Atkinson
Advanced Pilot Seminars
