Thread: Blow By Oil
Unread 09-27-05, 08:57 AM
Originally posted by KyleTownsend
I have been fighting oil leaks on the rear engine. I definitely have some leaks around the case bolts. But what can I do about it? How do you fix a leak around a case bolt?
Do you have an A&P licence? If you don't, do you know a mechanic that trusts your work? The job requires knowlege beyond preventative maintenance, and a calibrated torque wrench.
