Fred
The warning horn box is up in the roof port side centre panel. Just rip down the panel and there should be a silver box with 4 wires and a white connector by it.
This is a dual warning unit and it does both the stall and gear warning.
Did you disconnect the thottle micro switches on the front engine, just aft of the front thottle sw is a white inline connector, if you pull it apart it disconnects both micro switches, handy if you have a DVM as you can check both switches from here and set them up.
With the there should be no power at the brown wire on the warning unit with the selector in the up position.
Also check the white wire from the warning unit and with the thottle switches diconnected, connect a DVM to the white wire and make sure it does not go to ground, if it does the squat switch is faulty or you have a short circuit on the wiring in the engine bays.
Cheers
Pete
