Very strange??
Fred, a couple of questions.
On the '75 337G the stall and gear horn are wired up to the speaker, does the horn come thru the speaker?
It is a differant niose to the intermittant 'squeak' you get on the horn type (on older models).
Did you take out the throttle micro switches at dual warning unit??
As you operate the squat switch can you hear a relay operate in the center console?
If this relay does not energise when the squat switch is operated the horn will sound. So it does sound like this relay is intermittant, it is located in the center console above the power pack port side.
Let me know how you go on.
Regards
Pete
