Door Change
Ernie,
Thanks for all the good info, and I do understand the trouble you can get into whin you get tofar away from the way a machine was
built. I see in heacy equipment that its hard enough to keep them running let a long change the way a component was engineered.
As for the door change, I take it that you have done that?
I'm having a little door trouble from time to time, just like I did on early model 210 I had one time. And it seems every time its just a
switch or wire broken or pulled loose. But they want to go to the power pack every time. The last time it happened ,I stood a round
and they were stating to take the power pack out, and had not even ran a pressure check to see what it was putting out.
Man I got upset and told these to APs that a hyd system doesn't know what it's running ,could be lifting a dozer blade up and down or working with landing gear as in this case, And you guys are not pulling that power pack until we run some hyd numbers.
Turned out it was a wire coming down to the front nose gear.
So any way I do understand why you are thinking lets go slow
a little at a time. Thanks Erine We will meet some place next year.
Mark 740-988-9605
