Old 01-22-12, 08:33 PM
hew's Avatar
hew hew is offline
Thanks Herb, that would have saved me a LOT of bother! I like the idea of emailing the load sheet once you're done.
This is the best W&B app out there. You can have multiple aircraft and it works great. On the iPad is so convenient because you have it with you anyway. Just another great reason to have the iPad in the cockpit.
It's only $5.99
http://warbredstudios.com/flightscale/flightscale.html
Old 01-23-12, 06:43 AM
Herb;
Quick question. Does it let you save flight data? And if so, is there any way to print from it? Angel Flight requires a piece of paper to be faxed or mailed to them for each flight. Thanks.
Bill
Old 01-23-12, 07:01 AM
hew's Avatar
hew hew is offline
Downloaded this app and yes, sure does let you email directly from an iPad.
Originally Posted by billsheila View Post
Herb;
Bill
Old 01-23-12, 07:55 PM
Red Air Rambo's Avatar
+1 Thanks!
Old 01-24-12, 06:57 PM
Smile
It's only $5.99
After fooling around with this for a few days it really is a neat app. However, it is now $6.99...you got a good deal Herb!
Old 02-02-12, 08:30 PM
cessnadriver's Avatar
Talking Computerized weight and balance
Hello ALL.
I have a friend that customized an Excel spreadsheet for 4200 gross weight Skymaster!! We in the CAP use the Excel spreadsheet for all our airplane. It works great-best of all it's FREE!!
If any one needs a copy let me know. You have to have Excel though.
BILLS
Old 02-03-12, 12:30 AM
Hello ALL.
BILLS
You could post it here....but if you don't, I'd like a copy: learjetter_AT_gmail.com
Old 11-06-12, 08:00 PM
hew's Avatar
hew hew is offline
W&B on iPad
All you need is "Numbers" on your iPad. I have a customisable spreadsheet I can send anyone who wants it. You can email from your iPad or take a screen shot and email that to keep your minders informed.
Old 11-07-12, 07:10 AM
JimC's Avatar
JimC JimC is offline
I like this one for $4.99:
https://itunes.apple.com/us/app/wnb-...408836204?mt=8
because it allows for some pre-set weights at certain stations. For example, I don't have to remember how much my rear seats weigh - I can just move the "rear seats" slider to the right when they're installed, and to the left when they're not. I also carry some odd but specific cargo occasionally and it lets me add or subtract it with a finger swipe, and I don't have to remember how much it weighs or its station.
I use it to send emails of W&B for PALS (similar to Angel Flight) preflight.
Old 11-26-12, 01:38 PM
Weight and Balance Pro is really easy to use. It makes it so there is no excuse in knowing your W/B. Not sure if it is on Android or not but for the Apple products it's sweet.
Photos
1. Cover
2. Work Page for Skymaster
3. Envelope and gross
4. Building the stations
5. Building the envelope
ID:	1429   Click image for larger version
ID:	1430   Click image for larger version
ID:	1431   Click image for larger version
ID:	1432   Click image for larger version
Old 11-26-12, 02:25 PM
JimC's Avatar
One simple trick I use (which can be used on any app) is to make myself a permanent part of the solution. For instance, on W&B Pro (that's the one I linked to above) I can enter my weight & station and make it a "hidden" field that doesn't need to be updated each time. I just use the slider for the copilot's weight. After all, if I'm computing a W&B I know exactly who's in the front left seat.
Sure, I vary by 5-10 lbs seasonally but it's close enough.
Old 11-26-12, 06:32 PM
hew's Avatar
hew hew is offline
Numbers Spreadsheet
Here is a screen shot of the spreadsheet I use. The neat thing here is it's all on one iPad screen plus it has a quick fuel calculation at the bottom as one is often juggling load vs distance / fuel. You can email this page or take a "snapshot" of the page for future reference. (Press 'home' button and on/off button simultaneously to take a snapshot on an iPad). This spreadsheet is in kg lit & knots for Australia. I have a version in lbs & gal only for USA.
Name:	C337E Load Sheet.jpg
Old 11-27-12, 09:47 AM
Herb.
Thanks for the update. I contacted the Web site for B n W Pro. I unfortunately I don't own an I-Pod or I-Pad and asked them if they had a Windows version, they do not. They also said they didn't offer the Skymaster version.
Thanks any ways.
BILLS
Old 11-27-12, 04:57 PM
JimC's Avatar
You can program any the data for a 337 (or any aircraft) yourself. it's not hard and only needs to be done once. If you do get an iPad or iPhone, don't let the lack of a 337-specific template worry you.
Old 11-27-12, 09:31 PM
Bill
They only offer some common templates, like 172, PA 28, so as I posted photo 4 and 5 show the work page to make the Skymaster template. It's not a problem, any aircraft can be used.
