Old 02-16-20, 08:43 AM
Adapter
Owen Bell at Aviation Enterprises is also another source for the adapter.
Old 02-16-20, 11:54 AM
cessnadriver's Avatar
Smile power adapter for hyd. pump
wslade2.
I purchased the spline sockets from Sears paid about $40. It comes with about 10 different sized sockets. With Sears all but closed you can check the internet, or get them at Harbor Freight for $10. I know a lot of mechanics don't like HF quality but these socket and what you're about use them for it's fine. I don't remember what size fits the Hyd. pump spline,but you can figure it out. If you buy the HF sockets be sure you pick up a 6"-12" 3/8" extension that you can cut off the female end and install that into a 1/2" variable speed electric drill to turn the hyd. pump. You can buy the drill from HF as well-again quality not great but cheap to do the job! All for about $60.
Regards, BILLS
Old 02-19-20, 11:31 PM
Yup, just left harbor freight, got spline socket set for $9.95, goes right on the pump shaft. Already had drill, drill driver adapter, extensions, etc.
Old 02-20-20, 08:37 AM
Hydraulic pump shaft adapter
wslade2.
Good deal! Hope you have good luck with this procedure. Let us know how it go for you.
Regards, BILLS
