Unread 08-30-20, 12:29 AM
kbecker kbecker is offline
Rear Governor and Synchrophaser Overhaul
I need to have my rear governor and synchrophaser overhauled. The plane is a 1977 G, but it has the updated synchrophaser as shown in the repair manual for models with serial numbers greater than 1816.
The synchrophaser motor gear teeth are now uneven, and the potentiometer shaft is somewhat loose, also causing the gear on the end of that shaft to have warn teeth.
Any recommendations on a quality shop to overhaul this? I have searched the forums, but the data is pretty dated.
Thank you in advance for your recommendations.
Unread 09-08-20, 07:36 PM
85 views and no recommendations on shops?
Unread 09-08-20, 07:42 PM
Jhogan0101's Avatar
Jhogan0101 Jhogan0101 is online now
These guys are good. They are in Florida
863-875-4800
https://www.aircraftpropellerworks.c...ernor-overhaul
These guys overhauled my prop, im pretty sure they also do this type of work.
East Coast Propeller Services
Lancaster PA
717-627-7407
https://m.facebook.com/pages/categor...4082654700254/
337B
Philadelphia PA
Unread 09-10-20, 01:12 PM
QAA is awesome. https://www.qaa.com/
If you have an unfeathering valve it may be a considerable wait because that valve is only made by one guy in the nation. Call before sending. Otherwise good turn around time.
Unread 09-11-20, 01:20 PM
I don’t have an accumulator so I’m guessing there is no unfeathering valve. I do need some parts on the synchro slave unit replaced. That seems to be the issue with overhaul facilities.
