Thread Tools Rating: Thread Rating: 841 votes, 4.99 average. Display Modes
Unread 12-09-09, 10:20 PM
Originally Posted by larry bowdish View Post
There is a corrosion program, called CPCP. Regardless of the kind of corrosion your aircraft had from the factory, the SIDs (the CPCP is one of the SIDs) will require an inspection.
The corrosion program is voluntary and will only help to decrease the burden to do the SID's based on calendar. You would still have to perform the SID based on flight hours.
The corrosion program (CPCP) is NOT a SID. It is a separate inspection program.
The Cessna 400 series owners tried the litigation avenue and failed. Not that it may be a different case for high wing Cessna's but there is some history already.
