Unread 01-14-16, 10:49 AM
Stratus337 Stratus337 is offline
Stratus337 is on a distinguished road
Thanks James. I have an inverter pack and fog machine (kids' haunted house). What I'm trying to figure out is the best way to use the leaf blower to get air into the cabin to provide some pressure. Can I simply "connect it" to the air inlet near the cabin on the leading edge of either wing?
I assume the master switch will need to be on to allow the outflow valve to close? I'm at 1,000 feet here so I assume I dial it to the lowest position before trying to pressurize.
I should be able to fill the cabin with the fog and shut the door before blowing in air. Making sure the outflow valve closes and actually getting the air into the cabin are really the only two things that I need to figure out.
I'm likely going to end up at a shop, but would like to do a basic test to see if anything obvious jumps out before committing to spend that time and money.
