Old 02-11-19, 09:15 AM
kilr4d's Avatar
kilr4d kilr4d is offline
Rear engine
Originally Posted by tomcomet View Post
Up here in Canada I am flying around in 0 to -20C and even then I am breaking 400 degrees on #1 rear often and have to crack open the rear cowl flaps. Not normal and not great!
Your rear engine is a completely different story and imho it isn't an airflow issue.
The rear engine (except for cyl#1) is way happier than the front....higher fuel flow, gentler CHT rise, consistently cooler temps, etc. From what I see the #1 cylinder is an isolated issue.
Action items:
  1. Check fuel flows as per TCM SID using calibrated gauges.
  2. Check timing using a digital angle finder, not the old buzz box.
  3. Talk to GAMI about the #1 cylinder...confirm correct injector shipped and installed in correct cylinder.
  4. Fly and record an LOP mag test. A bad plug or wire can cause high CHT's.
  5. Clean injector and confirm flow from fuel injector block.
  6. Check for vacuum leak in intake manifold to cylinder.
  7. I hate to say it but also borescope the #1 cylinder just to make sure cylinder walls and valves look ok.
  8. Let's park ours sided by side, decowl and compare baffle seals.
Name:	cgrbr takeoff rear.jpg
_________
John K
1977 337G
CNC3
