Unread 08-11-20, 09:41 AM
Lightbulb
Ok, its not much of a mod, but I repaired the broken courtesy light circuit in the overhead clamshell door, and installed a 24 volt LED bulb that really lights up the cabin entry area, and runs cooler and uses fewer amps. You need a special two-contact type bulb - Here's a link to the bulb I used: https://www.amazon.com/dp/B00BZWLK6U..._hxPmFbJ27V21B I'll post up some night pics this evening.
Nice! Welcome to the boards. Wealth of info here, a fantastic resource.
My courtesy light in the overhead clamshell door is also inop (someone cut the wires where the door meets the fuselage). I'll try your bulb suggestion, if I can figure out how to get voltage to the wiring harness.
