Unread 09-12-22, 03:17 PM
If you have a parts manual use the hardware stack as show if the nut bottoms out on the bolt before the mount halves have contacted the internal space then add a washer under the nut and again the mount halves do not contact each other inside the mount if they do the mounts will be able to move inside the engine mount frame and that’s not good.
I’ve done 24 in the last few years. I do know how they go
I don’t mean to be snarky, I want to make sure you get it right
