Unread 05-26-23, 10:11 AM
Originally Posted by TomM View Post
Before I installed the Airwolf remote oil filter (which makes things WAY easier) I used the plastic baggie trick.....Crack the filter loose, slip a 1 gallon zipper baggie over it and unscrew it. Most, but not all of the oil goes in the baggie. Be careful if the oil is hot though!
Thanks, I use that method for filters that angle down from the adapter, but mine angles up at about a 45 degree angle. Maybe if I get the bag opening close enough to the adapter/case interface that will work.
Update: I managed to get the filter off without spilling a drop. I have to remove the intercooler for access to the filter, though, so I'd still like to find a way to drain it prior to removal.
