Unread 02-14-24, 09:25 PM
Joes Joes is offline
Aircraft Tool Supply ATS Screw & Bolt Remover (10") is the screw removal tool needed for the job along with a rivet gun. I use only IRWIN IWAF31PH220 20-Piece Impact Screwdriving Phillips #2 in high torque areas like the wing panel screws. While she was opened up i would change the gaskets on the fuel senders also. I always apply a small bead of PRC on the gasket and screw heads of the senders. JoeS
ps. there is a wing and tail boom support instructions in the manual.
