Unread 02-20-24, 09:11 PM
YankeeClipper's Avatar
Originally Posted by RandyArizona View Post
Well then, it appears you have your answer.
Why did you ask, if the answer you accepted, (and evidently called Textron and McFarlane) got their answer?
My first two questions still stand.
Have you seen this pump? Touched this pump?
Aircraft spruce page, weldon pumps.. listed at the top is PMA"d pumps,
17 boxes down is :
Cessna Single-Engine & 337 Aircraft 18000-B C291504-0201 Fuel Boost
08-07083
So, PMA'd, and listed for 337 aircraft.... Part number is correct, and if you call Weldon, I am pretty sure they will tell you it is the correct number.
OR
Don't take my word for it... Ask Weldon.
640 Golden Oak Parkway
Cleveland, Ohio 44146, USA
Info@WeldonPumps.com
PH: 440-232-2282
FX: 440-232-0606
Regards,
Randy
Well quite a lot transpired between 2:47p and your response.
I called Weldon during that time, for example, and they said that they had no PMA for pre-echo. In fact, the way they concluded that was by both of us browsing together to the FAA site where the PMA documents are published. We found eight of them, none of which mentioned anything before the echo models.
I have not seen or touched the pumps myself.
I saw the box you mean that only says 337, but if you click on the link for the part on that same line (for further details) it once again only lists Echo onward.
Good question about the parts manual... I'm still new to a lot of this; where can I find an updated version?
