| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Hi all
OK, if the RED HI light is on and you had an overvoltage, you would notice as some electrical equipment would fail, and a high indication on the ampmeter would be a clue. However if the RED HI light is on all the time even when the engines are shut down, the HI/LO sensor is inop. This unit is mounted on the port side of the center console, top above the HYD Power pack. The big diodes- They are wired into both alternator output and a reed relay is connected across the diode. In normal operation the diode is forward conducting and the relay sees about a 1 volt drop across the diode and remains de-energized. Should an alternator fail the votage drop across will be approximately equal to the buss voltage and the relay will energize and put a ALT OUT light on. The HI/LO sensor is field repairable however, they do not cost all that much. Hope this helps Pete |
| Thread Tools | |
| Display Modes | Rate This Thread |
