Unread 03-24-05, 08:46 PM
djarrett djarrett is offline
djarrett is an unknown quantity at this point
well Here is the results from the maintance shop. we cycled it ten time before the battery got low and then things stoped working. We always got a lite and the motor would run and hit 1500 when we hooked the system to an outside guage. So we couldn't duplicate the indications on the ground. we did notice that the main gear leg squat switches were a little loose so we made sure they were set properly, and secured. Did a little test hop to see if we figure out the problem. Gear up fine and with the generates off the battery never missed a beat. Once everything stabled we droped the gear no problems, the outside gage hit 1500 and the motor shut off and cycled once and then the pressure guage hose poped a hole and blew fluid all over everything and we went home and landed uneventful. We will try again wothout the extra pressure gauge after cleaning up the inside.
DJarrett
