Thread Tools Rating: Thread Rating: 46 votes, 5.00 average. Display Modes
Unread 07-14-12, 06:13 AM
hew's Avatar
hew hew is offline
Buying a 337
Here's a suggestion. Get hold of the SID's, most of these are visual inspections. Go through these with an A&P mechanic. Use anything you find to negotiate the price or abandon the purchase. The hard part of the SID's, if you are not going to stay in the Private category, is the three small screw holes in the spar, the jacking point and two next to it. To get them out you have to remove the fuel tanks as the nuts are not captured. Thanks for the foresight Mr Cessna.
Unread 03-01-15, 06:25 PM
jcskydriver jcskydriver is offline
jcskydriver is on a distinguished road
P337 pre buy inspector
Does anyone know pre buy inspector that knows skymasters some where on the west coast? I like to know someone that knows the plane inspect it on a pre buy, you can post it or email me thanks,
John jcgearup1@gmail.com
Unread 03-01-15, 07:33 PM
JeffAxel JeffAxel is offline
Dirk Wittig at Northwest Aircraft Maintenance at KHIO took care of my P337 for 3 years. Took the CPA 337 Systems and Maintenance course too. If the plane you are looking at is in the Pacific Northwest, his number is 503-648-3670. Good thorough guy.
Unread 03-01-15, 10:03 PM
P337 inspection
Thanks for the info! John
Unread 03-01-15, 10:05 PM
P337 inspection
West Coast is a large area, is there a specific location that you could provide? It may help to achieve a better response.
Sacramento area and the Southern Californian area, looking at 2 planes and seeing which I can get closer too. Thanks!
Unread 01-01-18, 08:08 PM
Nice Skymaster Article
This may be helpful for new Skymaster advocates
File Type: pdf Cessna Skymaster: - Aviation Consumer Article.pdf (787.2 KB, 16900 views)
Unread 10-13-21, 02:51 PM
Aviation Consumer -- Skymaster Used Aircraft Guide Article
Another good quick read with owner-specific commentary at the bottom of the page.
Link:
https://www.aviationconsumer.com/unc...337-skymaster/
PDF of article also attached.
