Unread 01-06-20, 02:36 PM
kbecker kbecker is offline
LED upgrade
1977 337G coming up for annual. I would like to upgrade to LED’s. The landing and taxi lights are straight forward. I need info regarding the wingtip lights/strobes and the tail light.
Are there drop-in bulbs available that do not entail removing current boxes/wiring?
Thanks in advance
Unread 01-07-20, 01:05 PM
Take a look at this link..
https://www.aero-lites.com/product-p...series-nav-set
Is pretty cool - and reasonable. I am doing for my plane this month.
Frank
Unread 01-08-20, 10:00 PM
A word of caution with these lights, they can cause some interesting radio noise if not using shielded wire. These may be fine but I would check with the company to make sure.
Approval?
Unread 01-10-20, 12:11 AM
I have both these position lights and landing light on my 182. Purchased at Oshkosh. I specifically asked while there about certification and legality and they reassured. My IA has had no problem with them x yrs. The position lights I have can "strobe"-which is not legal at night when they need to be constantly burning. Just be sure to "strobe" only during the day. At the show and in use, the landing lights seemed to put out much better light than the Whelen products. Plan to do the same with my 337.
Unread 01-10-20, 02:59 PM
From their website:
Are any certifications provided with your products?
Our products do not carry any application specific certifications. In general, the LED bulbs we offer are designed to perform as LED equivalent direct replacement bulbs for the respective filament-type incandescent/halogen commercial bulb codes. Each bulb is designed to conform to OEM-design specifications and performance standards including fitment, luminance and working voltage. By installing any of our products, you agree to the "Terms and conditions" set forth herein.
The "LIGHT EMITTANCE" meet the requirements for the airspace but the parts are not PMA or TSO'd
These would be legal for Experimental because they meet the light emittance requirement but technically they must have approval for certified aircraft
