Unread 04-22-09, 09:37 PM
RAY TORRES RAY TORRES is offline
RAY TORRES is an unknown quantity at this point
Hi Guys:
Normally I stay away from commenting here, but since the topic is my gear door mod I figured its time to clarify somnme things.
With regards to the RTAero gear door STC. The STC does not provide any procedural changes as to when to raise the gear or any changes in rates of climb/performance for before/after mod.
When we did this STC there was no doubt in our minds that the majority of the gear drag came from the large clamshell doors, and I think the modification has proved that out. I don't feel the wobbling or drag that I use to when cycling the gear before the mod. In addition, the modification removed 2 actuators and 4 hydraulic lines with no change in cruise or cabin noise.
As with most STCs, the FAA only requires that we show that the modified aircraft meets a minimum performance standard. In other words, you could modify the aircraft, and get approval for an STC where the aircraft performs worse or has no change from before being modified.
The FAA requirements to show improved performance figures is extremely cost prohibitive, thats why you won't find performance figure changes for most of your stol kits or other performance enhancing modifications. Normally you'll just get a general statement that the modification "improves" slow flight, rates of climb etc. The other side to this is the liability implications for the modifier when someone tries to fly to new performance figures and eats the trees at the end of the runway. Try to get hard numbers for any of the STC's out there and see what you get.
Getting back to the gear door mod. We did have to demonstrate to the FAA that the modified aircraft had positive rates of climb at 5000 feet and gross weight. We did a series of flights with front/rear and both engines in varying directions and averaged the results, and if my memory serves me right we averaged to around 100 fpm on the rear and about 60 on the front. But that was with an old tired airplane, performance will also be different depending on airframe and engine condition.
When you raise the gear is basically up to you. I raise my gear when I have positive rate and can't make the end of the runway. I do it even sooner if I'm taking off over water. But everyone is different and has to determine what is best for them. The "What ifs" are way too many to say one procedure is better than the other.
By the way, I blew a hydraulic hose the other day and had to sweat getting the gear down, luckily I had enough fluid to get it down and locked. But now I'm thinking that maybe the best solution is to just leave the gear down.
Best regards to all and thanks for supporting our mods.
Ray Torres
