Unread 08-23-02, 07:51 AM
For what it's worth, we found the actualy engine mount frame (or whatever you call it, i.e. *not* the rubber "mounts" that you change when changing the engine) on my '73 P337 had significant damage due to a cable that came loose and started rubbing on the *inside* of the frame, where the ongoing damage was not obvious. We had to remove the engine, have the frame repaired, and then reinstall. Fun (not).
