Thread: Landing gear
Unread 08-28-11, 08:24 PM
Tom Tom is offline
Tom is on a distinguished road
I'm thinking it might be an internal leak in one of the actuators, or a weak pump output. The higher flow/pressure of the mule would mask either problem. Try setting the mule at progressivly higher pressures from the lowest setting. You might also want to put a direct reading guage in the system to look at pump pressure.
