Unread 10-31-11, 06:25 AM
Voltage Regulator
Both alternators feed one voltage regulator. You can switch between the voltage regulator, in case one is bad. Sounds like you have one that is bad. The 60 AMP alternator will place significant loads on the drive shaft. I think most Skymasters have 30-38 Amp alternators.
