Unread 04-06-12, 12:12 PM
Shutting off your electrical for ten or fifteen minutes then turning it on and attempting to cycle the gear is something that should always be tried.
If you have a cutter and can cut the bottom of your pedestle away to get to the hydro powerpack, you can drop the gear manually by backing off the shuttle valve and relieving the pressure. It takes a wrench and you have to know the system, but it does work.
