Unread 10-24-13, 05:09 PM
Could the fuel have been returned to the AUX tank? The Turbo models are different from the Normal. The return fuel from the Turbo model has a path to the AUX tank. I am not sure if the T connection is plugged in the return system?
When you checked the vent lines did you use the procedure in the SM?
