Thread: Ammeter in 337G
Unread 05-05-14, 11:54 AM
AV8ing AV8ing is offline
AV8ing is on a distinguished road
Rod - The ammeter is wired to a fuse block that is mounted on the firewall just above the battery (not to be confused with the 2 other fuses higher up and in between the voltage regulators). The fuses are then routed to a shunt that is mounted directly below the fuse block.
Is it possible that the shunt is INOP ? Anyone know how to test this shunt ?
