Water in your Avgas
Paul,
Based on your last refuel in Arkansas, I believe that is where you took on the water. The fuel flow slowing down then completely stopping, tells me the pump filter system became laden with water from the tank, thus shutting down the flow. Also called "no-go" filters, these types of filters are supposed to stop the flow of fuel should they have water get in them. Perhaps it was this type of filter medium, however it did not react as fast (maybe an older filter).
