Unread 11-22-18, 09:24 PM
Hi Tripp,
You have had some nice panel work done and certainly have some additional real estate in the panel. I think you better review the STC for the 830’s. Near as I can tell, it is only approved to replace your EGT and CHT - you still have to maintain your original MAP, RPM FF, oil temp etc... This is why the cost is so low - if you want to replace all those you would have to with the 960.
In your case though, you would still have room to install the 830’s side by side where the EGT gauge is and to the right. Nice looking panel!
