Thread: 18x5.5 Tubes
Unread 07-22-21, 11:01 AM
Talcum powder?
I was taught that when you put a tube in a tire, you cover the inside of the tire with talcum powder so the the tube can "slide" into the correct position inside the tire.
Its possible the tubes are binding in one area, causing the wear.
When you install these tubes, try the talcum powder trick. It can't hurt!
