Unread 06-03-22, 04:44 PM
stevew stevew is offline
stevew is on a distinguished road
Check your trim servo motor to verify clutch/drive is mechanically disconnecting. 2 things happen when you run your trim. Clutch engages and motor drives. Sounds like clutch is jammed up and staying engaged. It’s not releasing mechanically when trim switch is released.
Lightly tap on trim servo to see if you can get it to release. Clutch/drive probably worn and won’t release.
