Unread 05-06-04, 10:04 PM
I WILL BE IN LONDON, CANADA WITH THE BOY SCOUTS OR ELSE I WOULD ALSO BE READY FOR JXN.
KEVIN,
OIL LEAKS ON THE FRONT, MINE IS A NORMAL ASPIRATED BUT I FOUGHT THE FRONT FOR MANY YEARS (15 OR SO) AND FINALLY FOUND THE SHAFT SEAL ON THE LAND GEAR PUMP. IT'S A LITTLE TRICKY TO REPLACE WITHOUT PARTIALLY PULLING THE ENGINE BUT WE GOT IT DONE AND IT HAS HELPED.
ALSO CHECK THE ALTINATOR SEAL
IT TOO CAN BE A SOURCE
