Thread: Blow By Oil
Unread 09-26-05, 03:23 PM
You're on the right track, dropping the oil to 6 qts. Some minor leak is normal, but you seem to have too much. Get your A&P to clean the engines (my guy uses a compressor pushing a mix of air and gasoline), then run it awhile (either on the ground or in flight), then inspect both engines carefully to see if you can detect where the leaks are coming from.
