Unread 01-03-03, 06:20 PM
Bob Cook Bob Cook is offline
N69S
var crank
Past posts indicate the reliability is not much different. The cost is about 7k for the crank and there may be some trade in allowance if you do a factory reman.
Check to see what the cases are. The HEAVY cases have an "H" stamped on the side. There will be a penalty on overhaul if you have the light cases. Also check closely around the bearing journals and insure there are NO CRACKS in the case before purchase.
hope this helps.
Bob
