Unread 04-01-13, 10:00 PM
When replacing the sender gaskets be careful to not over tighten the fasteners as you can warp the tank metal around the opening. It's a little bit of a catch 22 as if you don't tighten enough it may leak but you don't want to bear down on them. Try to tighten in opposite sides from the other rotating around the sender. This will apply even pressure to the tank seal. If it still leaks then Pro Seal is the next step.
Cheers
