On the first Skymaster I owned, N1873M, way back in 1975, there was an oil leak in the rear engine. It was the gasket for the alternator which is mounted on the rear of that engine. It was rather simple to repair however. On the rear engine there is an inspection plate on the rear bulkhead that opens directly to the alternator. Check the gasket on the alternator if your oil loss is minimal as that is what I found.
