Unread 08-07-26, 04:43 PM
YankeeClipper's Avatar
69D with cold cylinder mystery
Just completed an annual and after all is back together front #5 (copilot foremost) is running quite cool. After a few minutes of run-up the others are too hot to touch but you can hold a palm against 5 indefinitely.
The annual involved some engine control adjustments, but would imagine any such would affect all cylinders equally (mostly).
Things checked:
  • excellent compression
  • good spark (new sparks too)
  • valve springs strong
  • Nozzle flow equal to other cylinder
  • Mag check normal left to right and back
Any thoughts? Been two weeks of head scratching. Even called an IA with many many hours on these.
Unread 08-09-26, 11:47 AM
CenterlineT CenterlineT is offline
CenterlineT is on a distinguished road
Things checked:
I would change a couple of things. I would swap the spark plugs with another cylinder that you know it is hot, and test it again. If no change I would swap the injector. This is much easier if you have a digital engine monitor.
Unread 08-09-26, 02:59 PM
kbecker kbecker is offline
If you can rest your hand on the cylinder head then clearly there is no combustion going on in there. Air, fuel, spark.
I agree with swapping plugs and injectors, separately of course. I would also make sure you were getting fuel from the spider to #5. No spark could be a magneto or plug wire problem also.
Unread 08-12-26, 09:18 PM
Joes Joes is offline
Please let us know what you find. Joe
