Unread 09-22-08, 09:43 AM
tropical tropical is offline
Originally Posted by GMAs View Post
What part of the "... for Contenued airworthness" is the manufacture saying its recommended? The FAA seems to think its required at their set inspection time...
As you can read in the manual its really a test to keep you from having a air emergency due to electrical failure. So it seems to me that its a safety item that rates right up their with oil and gas
But you as owner can do what you want... however, next time you get ramp checked and they ask for the airworthy cert because it wasn't done use the recommended instead of mandatory arguement and see if it works.
The new buz word is " for Contenued Airworthness... it shall be done...
Fly safe GMAs
I
You are intentionally twisting the wording in this for your benefit. The service bulletin gives a "recommended" period for inspection, does not "require" it to be done at annual.
And yes, I'm an owner, and a A&P/IA.
